sharp arm207
  • vespa geoff
    • May 2009
    • 37
    sharp arm207
    hav a sharp arm207. copies from glass ok, but copy a4 or a3 through adf you get a black band about 25mm lead edge to trailedge. copies a4R ok. any help welcome
  • ZOOTECH
    Senior member of CRS
    • 3375
    Optics must be parallel and CCD might need a slight adjustment; this is assuming the adf sits proper and is not skewed.
    • OMD-227
      Yeah.... I'm with Zootech.
      A 25mm thick band sounds about the size of one of the mylars under the ADF. I dont work on this series, but it sounds exactly like a similar issue with a Whale series machine when the ADF is skewed and a mylar just sits over the slit glass, causing a band across the page. Your A4R copies wouldn't register this problem as it would be one of the mylars on the outside.
      Check the ADF is sitting straight or clean the optics and slit glass REALLY well.
      • vespa geoff
        • May 2009
        • 37
        arm207
        thanks for replys .will check these mylars as the adf seems to be sitting and positioned correctly. when i go back tomorrow, happy days
        • OMD-227
          A 25mm wide band across the page is quite large. Its not your regular ink stain or white-out size marking on the slit glass. It could possibly be part of the optics/cable hanging down between there and the CCD. Something is blocking the light. Look straight down through the optics to see the CCD. You might see something there causing this.
            • 23008
            I've had to trim a millimeter or two off of those ADF mylars on a couple of occasions. They can become quite mangled. =^..^=
            • vespa geoff
              • May 2009
              • 37
              arm207 blackm band on adf
              hi quick update, well cleaned optics /ccd and adf till blood ran. checked mylars seem to be ok . copies 100 per cent better but still not sure of cause . been now been told machine handles rough when moved from one office to another and may be the adf might have been twisted but it looks and sits ok. will see what happens over next week.cheer for all help
