Jupiter AR-M451N. Problem code L4-2
  • vlad_
    • Jul 2008
    • 99
    Good afternoon colleagues.
    At the copier flashed an error code L4-02. Drum motor lock trouble. Drum rotates easily. Clear the whole block of the drum vacuum cleaner. Smeared with grease axle drive Dram unit. To work. Photocopies produced about 600 copies and error L4-02 to light again.
    Thank you for your help.
  • OMD-227
    If you are sure the drum & process unit are OK, change the MC unit. I know it sounds crazy..... but trust me.
    From memory there was another post on this code a few months back. Get more info there if you can find it.
    • ravikumarj
      • Apr 2007
      • 49
      Drum cycling gears are modified in the drum unit. Hv you replaced with new set of gears.? Previously nylon gears. now it is a black gear. pl change all the gears .
      Ravi.
      • bilyahn
        • Dec 2006
        • 1470
        Had one of these just the other day and it wound up being the DV unit.
        • vlad_
          • Jul 2008
          • 99
          Thanks to colleagues. The idea of MC unin and changed my gear will be tested soon.
          Thanks again.
            • 23010
            I've had a shorting HVT lead produce this effect. It's part of the main drive assy. =^..^=
            • Dark Helmet
              • May 2009
              • 868
              had this a month or so ago, every thing turned great, (drum unit, dv unit, drive unit). most times power cycling would get rid of the error. Still turned out to be the DV unit. it was hit and miss but the bloody thing was shot after 400k on it. I would turn the mag roller backwards and then go forwards and it would be smooth again.
              I find on this series if you have around 350k-450k on a DV unit, toss it. They are usually worn out by then.
              At the 300k PM if that unit has any signs of turning rough at all it gets replaced at the next PM
