Sharp arm276
  • I AM A PHOTOCOPIER ENGINE
    Sharp arm276
    Hi i have a sharp ar276 all up to service but is extracting the developer from the dev unit.its pulling quite a bit through the machine causeing jaming issues.THe copies are perfect no background at all no error codes either.Any ideas would be greatly recived.
    • 23009
    I don't recognize the model number. Is this a UK version of the Leopard? If so, replace the drum, blade, and developer together at the same time. It's the drum that causes the developer to dump. =^..^=
    • DINGO
      • 661
      Yes, this model exist in UE, sharp arm-236/276.
      • Comingapart
        • Jun 2008
        • 44
        Also, make sure the DV seal isn't curled and that the white pads at the sides of the mag roller aren't worn.
        • mtech
          • Mar 2007
          • 307
          Also check the left door for warping. Connections to the transfer roller unit are on the door. Make sure there is good contact when the door is closed and that they are clean.
