Sharp AR-172M- Sharpdesk please help
  • kazimnaim
    Dear All
    I have recently purchased a used Sharp AR-172M Machine
    I was trying to scan-email from the machine panel but always getting a CE-02 or CE-00 errors
    Downloaded the Sharpdesk software from the website but it requires serial number which I dont have
    Kindly advise what to do as I dont have any Manual or CD key with me
    Thanks and regards
  • wtroll
    • May 2008
    • 85
    SharpDesk is a non-free software.
    When you purchase an MFC Sharp with the scanner option actived (like your AR-C172), you must check to have the related licence & serial number!
    Otherwise you can go into the web page of your MFC Sharp and insert the correct parameters of GATEWAY, DNS and SMTP.
    Than you can go into the ADDRESS BOOK field and create a new e-mail destination.
    Good luck!
    • kazimnaim
      Dear Sir,
      thanks for the reply
      I have already setup Gateway, DNS and SMTP. Still when I scan and sent to email from the machine it gives error CE-02 and sometimes CE-00
      Kindly advise
      regards
      Originally posted by wtroll
      Good luck!
      • wtroll
        • May 2008
        • 85
        Ok,
        here is a tech bullettin about a similar problem:
        QUERY: CE-02 trouble when performing a Scan to E-Mail even though the IP address of the mail server is correct
        ADVICE: Check the STMP Port setting of the mail server. Port25 is the default STMP Port setting on the MFP however, the mail server maybe using a different port (eg. Yahoo Mail uses SMTP Port 465)
        Try this way.
        • kazimnaim
          Hi there
          Using a local ISP mail server and server settings are same as port 25. Ive checked this in Outlook also
          Still the same
          regards
          • tmaged
            Owner/Service Manager
            • 1880
            In the first thread you referenced Sharpdesk. You're not trying to use it correct ? As far as scan to email, it sounds like you know what you're doing. I would try the IP address of the SMTP server instead of relying on DNS to resolve the host name.
            Hope that helps !
            -Tony
            www.dtios.com
            Become a fan on Facebook
            • kazimnaim
              Thanks for reply
              No. Im not using sharpdesk as I dont have the serial number for that
              Im trying directly from the machine to send scan-email which is giving me errors. I have tried with the ip address of the mail server and still it gives the same CE-02 errors. Its a direct connection
              thanks and regards
              • Techace
                • 35
                give me your email address. I will send you the serial number
                Originally posted by kazimnaim
                Thanks for reply
                thanks and regards
                give me your email address i will send you the serial number.
                techace
                U.A.E.
                • bilyahn
                  • Dec 2006
                  • 1470
                  Thanks for reply
                  thanks and regards
                  I have had this problem and had to rename the copiers domain name to match the domain you are emailing from. For some reason it was blocking the email function of the copier. As soon as the domain names matched the problem was solved.
                  Good luck.
                  Bil
                  • Peter Sim
                    • Sep 2008
                    • 445
                    Ok,
                    Try this way.
                    may i know where to set the port number on the MFP machine
