AR-M455 default exposure setting
  • oldrn
    • 166
    I am trying to set this copier so that the default exposure setting is text mode so that blacks are black instead of gray. I have gone into key operator settings and set the initial exposure setting to text. I have gone into sim 46-19 and set the AE Mode to 1 which is supposed to help "provide high contrast images" in auto exposure mode. Sim 46-19 Auto fixed is set to off. Text mode 3.0 in sim 46-2 gives me the result that I want while in simulation mode. When I make an actual copy with initial settings, the copies still come out looking like the setting is auto exposure for text/photo mixed which gives a grayed out look to the solid black circles from the test chart. It isn't a toner density problem since manual text 3.0 gives perfect black circles as needed. Toner save mode is off. I must be missing a step somewhere. Any help would be appreciated.
  • igi
    • 1507
    m455
    hi
    is there settings to choose default dpi-300 or 600
    try thath
    cheers
      • 23008
      Custom Settings, Key Op Program, 00000, Copy Function Settings, Initial Status Settings, Exposure Mode...
      It's in really small type on pg 8-3 of the AR-M350 service manual. There is no mention of it in the 8 pg Key Operator Programs manual.
      • oldrn
        • 166
        Thanks for the replies.
        Blackcat. I did go into key op initial exposure settings and select text. Even though I select text mode, if I go out and come back to this setting, text is not highlighted. I assumed this was normal since I had seen it on other similar models.
        Igi, I don't see a choice of dpi for copying.
        I think I need to go back to the machine and look things over again. If anyone has other thoughts on this problem, feel free to join in.
          • 23008
          There is a trick here that I can't remember exactly how it works. It has something to do with the way that you lock in your choice. I must have tried it a dozen times before I got it to stick. Sorry, I don't remember details. Wazza, help me here. =^..^=
          • oldrn
            • 166
            The "trick" to fixing this one might have been turning it off and back on. I went back and the problem was no longer there - copy quality was as desired. Thanks to all for input.
            • repn1999
              • May 2010
              • 310
              if you put it on slow scan mode from platen you get 600dpi scanning. Just FYI
