mxm-450u
  • vespa geoff
    • May 2009
    • 37
    mxm-450u
    hi all
    I have a mxm450u when you do a 2 to 2 copy from adf you get one side ok, but slit glass side has vertical
    lines and dirty copy . If you feed single side copies through they come out nice & clean , from glass ok too
    it only seems to be 2 to 2 copies when fed through adf . any help welcome
  • gwaddle
    • May 2009
    • 782
    Seems to me the slit glass on the adf lid has to have something on it, that's where the second side it scanned.
    I know I should be ashamed of myself. Strangely though, I am not.
    • vespa geoff
      • May 2009
      • 37
      mxm-450u
      all optics nice and clean
      • ZOOTECH
        Senior member of CRS
        • 3375
        Side one is scanned with the slit glass (original face down in doc feeder), second side is scanned with the CIS unit (if I'm not mistaken).
        • vespa geoff
          • May 2009
          • 37
          mxm-450u
          this is a first side problem [slit glass] not lid !
          • bilyahn
            • Dec 2006
            • 1470
            When you test the copy lamp for the 2nd side (CIS unit) do all of the LEDs light up?
            • bilyahn
              • Dec 2006
              • 1470
              I'm not sure I understand, if you are doing single sided and the copy is good (slit glass or platen) then the slit glass side of the 2 sided should be fine also. Do you have any images we can look at? What do the copies look like when you do a 2 sided original to 2 - 1 sided copies (the 4th option in the two-sided menu)?
              Good luck.
              Bil
              • vespa geoff
                • May 2009
                • 37
                mxm450u
                re 2x2 problem .
                spoke to sharp tech advised me to change drum /dev /charge and machine now working .
                  • 23008
                  There has got to be more to this than meets the eye. Your description of the problem does not match with the fix. According to you, you fixed an optical problem with a print engine solution.
                  Replacing the drum, developer, and charge unit would affect both sides of all prints equally, not just one side of duplex prints. In other words, the same drum, developer, and charge unit are used to make the image on both sides of the page. Either your problem is not fixed and temporarily went away, or you have described either the problem or solution poorly.
                  So vespa, what is your theory exactly what fixed the problem? =^..^=
                  • Dark Helmet
                    • May 2009
                    • 847
                    Sounds like PFM
                    • vespa geoff
                      • May 2009
                      • 37
                      mxm450u
                      re problem, all i know contacted sharp tech uk advised to change parts as listed machine now working
                      customer happy , me too will post if any change
