ARM-276 DADF lines
  • vlad_robas
    • Oct 2006
    • 225
    ARM-276 DADF lines
    Hello,
    I bought this used machine and i just realized that it has this problem:
    - if i place the original in the ARRP7 feeder copies come out with some black stripes ( lines) (they are more gray than black is very possible that i have to change drum and dev. couse black isnt black and it has a very low value in 25-02, but that's not my problem yet) if i copy from glass copies are ok, i cleaned glass, mirrors, DADF ... I don't exclud the possibility that during the transport something heavy put over the copier. If i pres the DADF in the time that is scanning the copies have less lines but at first wiev looks in place.
    And isn't an worn drum&blade even if it looks like.
    For better understunding i put some copies made with it. An image is like 1000 word's in my case 100000 couse of my engleski.
  • lky1978
    • Mar 2009
    • 482
    Something related with the optical area, try to clean mirror。
    • wtroll
      • May 2008
      • 85
      Hi,
      I know this problem.
      You must adjust the RADF scan position by sim. 53-8.
      See attach.
      • vlad_robas
        • Oct 2006
        • 225
        Thank you wtroll, i will try this first in the morning.
        lky1978 u should realy read my post twice before posting that ''solution'' which doesen't aplly in my case couse when i copy from glass copies are ok.
        Im not posting here to bore people couse i didn't cleaned mirrors.
        • vlad_robas
          • Oct 2006
          • 225
          Problem solved, thank's aagain.
          • vlad_robas
            • Oct 2006
            • 225
            i'm back with some problem's on the same machine.
            We did use it for a while then we didn't now we need it again so my coleague tels me he does that lines and i did that 53-8 adjustment and I did noticed 2 more problem's:
            Is modifying the size of the copy is making it smaller with about 2-3 mm.
            It only see EXTRA-format from RSPF, i've checked the sensor's in 2-2 and the sensor's ar ok but it only see EXTRA if I select it manualy it make's no diference.
            • wtroll
              • May 2008
              • 85
              Use sim. 53-6 to adjust the detection level of the RSPF width (perform all 4 steps) for the "Extra" problem.
              Use sim. 48-1 to adjust the copy mode magnification ratio (main and sub. scanning directions).
              Refer to the Service Manual for details.
              Good luck!
