CQ issue in hercules machines
  • sundakib
    • May 2010
    • 23
    [CQ] CQ issue in hercules machines
    while doing back to back copy thro DSPF first side copy is very clear.
    second side only rear end is giving black back ground.front side is clear.
    How to adjust only CIS unit.
  • OMD-227
    As with most Sharp's, make sure the optics are clean, then run the shading correction in 63-02. You can select just the DSPF.
    There have been quite a few changes done to the DSPF in relation to dust resistance improvements. Production after Feb 2010 has this already implemented. Otherwise, see attached images and use them if the machine is affected by dust. Its a big job, but worthwhile.
    Send me your email.... I have some documentation on the Herc's you might find very useful if you will be servicing them in the future.
    • sundakib
      • May 2010
      • 23
      Thanks wazza. My email id is sundar_sharp@rediffmail.com
      • sundakib
        • May 2010
        • 23
        Thanks wazza i got it
        • leo34staffs
          copierman
          • Aug 2007
          • 496
          Re: CQ issue in hercules machines
          Can you send me some info on the machine, we are installing one this week and would be good to have a heads up on the machine, Thanks
          Networking skills are advantageous but use of a 3m vacuum cleaner is essential
          • Akitu
            Legendary Frost Spec Tech
            • Oct 2010
            • 2596
            Wazza/OMD227 is no longer on CTN.
            Necro thread!
