Ar-m277 / ar-m257 f2-02
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1885
    Just curious if anyone is using Katun toner AR310NT and getting an F2-02. We've used OEM all along, tried the Katun for a few months then everything seemed alright. We've now had 3 machines in the last 2 weeks give us this errror.
    Thanks,
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • 23008
    I've never tried the Katun toner on an Andromeda.
    On Canon, on Ricoh, on Mita, the results were always disappointing. I wouldn't have done it.
    Perhaps you'll have better luck with the Katun developer used with the Katun toner. Rumor has it that you'll get better results. =^..^=
    • tmaged
      • Oct 2008
      • 1885
      I haven't been thrilled with Katun toner on anything after the Cougars. BUT when you have the number of Andromeda's out with the volume that's run, I figured a savings of around $1500 - $2000 annually. Well see if it's worth it.
      Hope that helps !
      -Tony
      www.dtios.com
      • bilyahn
        • Dec 2006
        • 1470
        We used to use Katun toners a lot but anymore we stick with OEM. Mostly due to CQ issues and some F2 codes.
