AR M277 Fuser
  • patwilf
    Service Technician
    • Nov 2009
    • 41
    AR M277 Fuser
    just trying to figure out if you are supposed to grease the upper heat roller bearings when replacing the roller.....the book doesn't say anything about it......just curious if anyone else is doing so
  • johnbla
    • Apr 2005
    • 94
    You don't, unless you want a heap load of grief, it is designed to run 'Dry' in the Thermo-plastic bushings.....
    Anything gets in there and the whole Fuser Unit will grind to a halt and that will really annoy the Main Motor and Drive interface gears....
    You can wipe the Cleaner pad, UFR & LPR with a little bit of 'silly'oil to help things long
    regards
    John
    sigpic
    " The Game never ends..When your whole World depends..On the Turn of a Friendly Card..."
    • patwilf
      Service Technician
      • Nov 2009
      • 41
      thanks for the quick response.....i was thinking the same thing.....just needed some back up.......thanks again
        • 23010
        ditto. =^..^=
