sharp am900 p5 code
  • gregu33701
    • Oct 2008
    • 31
    [Error Code] sharp am900 p5 code
    besides replacing the fuser is there any other "reset" procedure for resetting the code, the service manual does not indicate any service mode
    • 23006
    Sharp products typically reset fuser error in simulation 14.
    I am not familiar with this particular Sharp, but it looks like a cross between an FO-DC550 and an AR-153. I found the Users Manual , but not the service manual.
    I'll keep looking. =^..^=
    • OMD-227
      P5 code is a High Temperature error. Check fuser rollers & thermistats. Possible thermistat popped or toner buildup on it causing incorrect temp reading.
