u2-50 code
  • bonnie750
    • 302
    u2-50 code
    a colleague has been to a mxm503n which was 'copying slowly'. when tested against the watch it took 1m 50secs to copy 50 single-sided a4 pages.
    he has updated the firmware to the latest and greatest and m/c now shows u2-50. it won't clear with sim 16. i attended the machine to help him out and disconnected the hdd and the same code displays and will not clear. i thought about formatting the hdd but the only sim listed in 62 is 10.there are no more sims listed when there should be 10.
    i'm thinking that the firmware is corrupt though it loads without a hitch. we had to leave as they were all going home so i haven't had the chance to load an older version of the firmware.
    i have seen machines copying /printing slowly when the hdd is a bit flaky but this is a variation on that theme i haven't come across.
    your input is most welcome
    Bill
    • 23008
    I'll qualify this by saying that I've dealt with similar issues on Kyocera products. Some of this may apply.
    The printer can print only as fast as a complete page of data can be received. My customer was sending ledger sized technical drawings via a DOS based ancient application. The printer was rated at 80 ppm. They were printing at ~4.5 ppm.
    There were a lot of complicating factors here so I'll try to break them out separately:
    1) ledger size prints count as two clicks. Double that speed.
    2) the network has very high traffic level. Lots of collisions.
    3) the DOS based application is the slowest possible way to send any print data. I took data captures and sent them various ways: via the printable data line in the Command Center, via IC Link utility, via LPR Jar utility, via Command Line. The Command Line was the slowest, by double.
    4) The print jobs were in PostScript. PostScript print jobs always take longer to spool than PCL6 print jobs.
    To test the print speed more accurately hook up your laptop via crossover (remove the network from the equation). Print from the standard manufacturers driver for that specific model and operating system (not a generic driver, in-house written driver, HP4 driver, or anything else). Use a standard application like Adobe, Word, etc. Don't count the wake up time from sleep mode. Now what is your print speed? I'm betting it's a lot closer to the manufacturers rating.
    My customer's stock answer to all my questions was " ... well, that's just the way we do it ... ", and thus the results.
    With all that being said, U2-50 is a HDD checksum error indicating a bad hard drive. You may get lucky, and recover with a reformat. But I would not count on that changing your print speed. The DIMM memory would be more likely as a hardware-related cause of slow printing. =^..^=
    • OMD-227
      By any chance, does the machine in question have a fax unit or DSK installed?
      Also, is the User Authentication activated on this machine?
      • bonnie750
        • 302
        hello wazza
        no neither of those are installed and they haven't got round to setting up users yet. i've downloaded an older version of firmware, cannot think of anything else mate.
        • bonnie750
          • 302
          think i might have sussed what happened here. the zip file is named mx363n-m503n626.zip for the u version
          but the n version is mx363n-m503n440.zip. i reckon he's looked at the file name and assumed the first in the list was the n version. the machine must have u firmware (i hope) which may explain the problem.
          looking down the list of firmware files for download they are all named mx363n-m503n whether they are intended for the n or u version.
          • OMD-227
            You might be onto something there. A network version vs Non network version installed incorrectly could very well do that.
            Have never seen incorrect firmware installed, as it usually gives error code or lockup during process, but definitely try correct firmware.
            Here's our current version details......
            • bonnie750
              • 302
              i loaded the n version firmware and that fixed the u2 problem but the machine still runs at virtually half speed.i ran the m/c with the mx-fn10 and the mx-rbx3 removed and its still running slow. next stop the controller shop!
              • OMD-227
                Mate... This one is making me think too hard.
                So this is a stand-alone machine, with no user control or vendor mode/swipecard/coin box activated. Just a stand-alone machine that 'copies' slow. Is this printing & copying speed affected, or just copying speed as your original post states?
                There are known issues of machines going slower in vendor modes (with a few sim changes to fix this), and a older firmware upgrade to solve a slow printing issue with user authentication activated. If your machine is totally standalone, I agree with Blackcat on the laptop & crossover cable idea (which I have done previously to prove network faults) as this will rule out the machine or network at fault in your case. If copying is slow as well, the only thing that comes to mind is either memory fault or MFP board fault, accessing the memory too slowly, like an onboard processing issue.
                • bonnie750
                  • 302
                  hello Wazza
                  good one eh?
                  machine is 6 weeks old ,standalone copier with mx-rbx3 and mx-fn10.
                  sharp tech support have an identical machine which copies 50 a4 lef, no offset in 51 secs, this
                  box takes 1min 55 to do the same.
                  i've got a case number from them and on their suggestion i'm ordering a controller.
                  i double checked the machine spec in sims in case the wrong front door had been fitted,
                  but no it is correct. hey ....any port in a storm!!!!!
                  bill
                  • OMD-227
                    Try a device clone, then run NVRAM clear.
                    If it makes no difference at least you can still reload the clone as everything will be reset.
                    • bonnie750
                      • 302
                      thanks mate, i'll give it a go
                      bill
                      • Dark Helmet
                        • May 2009
                        • 853
                        Is this thing running slow in copy mode as well or only in Print?
                        I had a customer printing on paper size 5.5x8.5 and it put the machine down to 20ppm. I know differnt paper types can also slow the machine down. Is it possible the print job is saying it's a differnt paper type or size and slowing down the copier?
                        If this happens in copy mode as well throw out what i said.
                        • bonnie750
                          • 302
                          the machine is copy only i'm afraid mate
                          bill
                          • OMD-227
                            Get a copy of the job log data from the webpage.
                            Check if there are any error codes like 0201, 0202, 021E, 042C listed there. These are 'memory full' errors, which would indicate a possible problem with the copy memory modules. Also run 60-01 memory R/W test.
                            Swap out the memory and test again. If its copy only, the only times I've seen something like that was memory problems & MFP accessing memory.
                            • bonnie750
                              • 302
                              Been back to this machine today. the customer had managed to jam the paper pass unit half in and half out.
                              fixed that and decided to redo all the connectors on the controller board and then work around the others. after the controller, fired it up and 51 copies in 60 secs.....right on the money. problem is i've got no idea which connector(s) was/were the problem.
                              at least it's working....
                              thanks for the replies.
                              Bill
