sharp ar-200 paper jamming
  • ztorque
    • Aug 2025
    [Jamming] sharp ar-200 paper jamming
    i have a sharp ar-200 that is jamming the paper right next to the drum unit can someone tell me were i can find a tech in the orlando fl area.
    thanks
  • Silvertoast
    • Feb 2010
    • 270
    looks like the gear has stripped in the fuser and isnt turning, as far as a tech use the yellow pages
    • ztorque
      do you know how i can fix this on my end or maybe a site to buy the parts that i need
      thanks
      • OMD-227
        Silvertoast is right by the looks of it. The fuser drive gear has a small pin which breaks off after a long life and causes the upper heat roller to stall. The pictures are a good example of what happens.
        The part for the gear is NGERH0540FCZ3, or replace the whole fuser unit if the rollers are worn & the frame is warping.
        • ztorque
          ok thanks, you know were i can get this parts from.
          • OMD-227
            Geeez mate, call your friendly local Sharp agent. They'll have it in stock.
            Look them up. Its not something you can just pickup anywhere OK.
            • ztorque
              ok didn't think i was going to get you upset sorry, im not a tech guy and i never order any parts for something like this but thanks anyways
              • OMD-227
                Who's upset??
                Not me.
                You need a tech to look at your machine. They will have the parts required.
                I gave you the part number, and if you are a keen 'tech type' person who would like to have a crack at fixing this, then go for it. You just need to buy that part first.
