NOTICE: Users should expect a few periods of downtime this evening while we work on a few updates to the system.
Silvertoast is right by the looks of it. The fuser drive gear has a small pin which breaks off after a long life and causes the upper heat roller to stall. The pictures are a good example of what happens.
The part for the gear is NGERH0540FCZ3, or replace the whole fuser unit if the rollers are worn & the frame is warping.
ok thanks, you know were i can get this parts from.
You need a tech to look at your machine. They will have the parts required.
I gave you the part number, and if you are a keen 'tech type' person who would like to have a crack at fixing this, then go for it. You just need to buy that part first.
