AR-163 with L6-10--Put new polygon motor but still get L6-10
  • axyun
    • Aug 2007
    • 1323
    Getting L6-10 on AR163 and put new polygon motor RMOTN0022QSZZ in but still get L6-10. Does that mean problem in harness and need to change whole unit or is it MCU board? Just thought I'd ask before taking machine apart again and replacing whole unit. If I do that I will inspect harness for something obvious. I ran 25-10 and heard nothing at all. 30 seconds later the sub number 10 was flashing so I know it took the simulation. Any advise is appreciated. Frank/ActionPhotocopy
  • eksper_ankara
    L6-10
    l6-10 polygon engine failure. lsu in care and improves cleaning
    • axyun
      • Aug 2007
      • 1323
      I am not sure what you are saying about cleaning and improves care. I changed the polygon motor which usually solves the problem unless problem in harness , connection to board or board itself. I f it could be something else please advise. Frank
      • Dark Helmet
        • May 2009
        • 835
        We always replaced the entire LSU when this code came up.
        There was a bulletin on a new style LSU which is a lot cheaper than the old style.
        Part# DUNTK0185RS11 - LSU
        Part# DHAi-0106QSZ1 - Harness
        The bulletin also says you need to change the harness. I don't remember ever doing that but for the cost of a $5 harness better to be safe.
        • Silvertoast
          • Feb 2010
          • 270
          i would reccomend replacing the whole lsu
            • 22999
            The thing to watch on the ribbon cables is copper leads peeling back from the edge that inserts into the connector. When I worked on these machines, I always replaced laser unit assemblies. I've never tried it any other way.
            You know there are lots of other components in that laser unit. I could be the laser diode, or the BD sensor. =^..^=
            • axyun
              • Aug 2007
              • 1323
              Thanks Lawrence ,Chad + David . Your input is much appreciated. I will post results when call is complete. Frank
              • axyun
                • Aug 2007
                • 1323
                Took machine apart again and when I swapped harness and reassembled machine and it is working now. I took old polygon motor out of garbage as I assume it is good.Thanks to all. Frank
