AR-M350U - For a Girl Scout Troop
  • 92DIESEL
    • Jun 2025
    Hello,
    We recently received a donation of a Sharp AR-M350U copier for our Girl Scout Troop.
    So, no, I am not a tech.
    I have a few questions, if anyone can help, we thank you in advance.
    1- It has an auditor on it (SF-EA12) can this be removed? (Found a code in the service cards to enter to let us copy)
    2- We can print to it using a parallel cable, but receive the message ##Your entered account code is not registered, however printing was completed. Consult your key operator for registration of account code. ##
    3- We installed a new toner cartridge, and the first 10 copies we perfect, but now the entire paper has streaks and a shadow of what was printed half way over, almost like it made a duplicate copy 4" over, just not as dark.
    One thing to point out was that when it was delivered to us it was laying on its back, Don't know if that does anything or not, just letting you know.
    I called a company here locally and they want $200 just to come out. We just can not afford that right now, so any charity of information that you men can give us will be much appreciated.
    Thank you again,
    Troop 40726
  • OMD-227
    The most critical part of that entire post, was the fact you mentioned it was laying on its back.
    Believe me..... that ain't good at all!
    If there is no developer & toner spills through that machine, it would be a miracle. I would totally say that the cause of any copy quality issues is the fact it was transported very incorrectly. Copiers are not designed for that at all.
    The auditor can be removed, but it generally involves accessing the PCU board, to disconnect cabling, and entering service mode 26 to disable the settings for any coin box/swipe card device which has been installed. This will help with the messages you receive when printing.
    Best advice, get in a tech. Shop around. They will have the parts needed and the experience to help you out.
    • ZOOTECH
      Senior member of CRS
      • 3375
      Agree totally; see if you can find a dealership like ours that jumps at a chance for charity work (re: tax write off) or maybe barter for cookies.
      • OMD-227
        Typical......
        I knew you'd jump at helping the girl scouts!
        • JustManuals
          • Jan 2006
          • 9838
          I bought 2 boxes of cookies yesterday. To the original poster, if you send me an email at paul@justmanuals.com I'll send you a free copy of the parts & service manual.
          Paul
          • 92DIESEL
            Just an FYI. Thankfully the toner was completely empty before it was shipped. Sure hope that helps.
            One more thing, is there any way to get a copy of the software that runs this thing? I think they said it was sharpdesk, but they did not have any of the original documents or software.
            Thank you again all!
            • OMD-227
              Yes, having an empty toner during transport would help alot, but I'd hate to see the developer unit right now.
              A damaged dev unit or possible fuser unit damage (or pressure levers up) would be causing the 'shadow/duplicate' image you mentioned.
              I still say you'll be needed a qualified tech check this unit out, especially if it was not upright.
              As for the software, the drivers are freely available on the Sharp website in your country. This will enable PC printing.
              Scanning software (sharpdesk) is usually also available to download, but you'll need the sharpdesk licence that comes with the machine. You'll also need the optional scanning hardware installed in the machine, as well as use the network card, not parallel.
              Get a tech. My good deed of the day.
              • tmaged
                Owner/Service Manager
                • Oct 2008
                • 1867
                If it's a U version, you won't have scanning unless the network board & scanning have been added.
                Downloads | Drivers | Manuals | SHARP Customer Support Electronics Here's where you can get the drivers.
                Hope that helps !
                -Tony
                www.dtios.com
                Become a fan on Facebook
                  • 22997
                  Originally posted by 92DIESEL
                  ... 2- We can print to it using a parallel cable, but receive the message ##Your entered account code is not registered, however printing was completed. Consult your key operator for registration of account code. ##
                  Troop 40726
                  In the driver properties there is a section called job accounting, or something like that. Your machine has been set up to track usage by job accounting ID #. When you remove the auditor, and change the setting in simulation 26 that message will go away.
                  If you have gathered from the others, laying a copier on it's back is comparable to laying your car on its roof. It's just not designed to sit that way. And it will be extremely dirty at best.
                  I agree with the others that you really need a professional to address these problems. Unfortunately, amateurs often end up costing themselves even more in the end. =^..^=
                  • 92DIESEL
                    Thank you all very much for your support.
                    Anyone near the eastern panhandle of West Virginia? We have cookies!
                    Seriously though, thank you all.
                    • OMD-227
                      Send some down here............
                      Hope you get that machine sorted out. Its always nice to get a freebie.
                      • JustManuals
                        • Jan 2006
                        • 9838
                        He's got the manual now too.
                        • DavePo
                          • Jul 2008
                          • 303
                          ]He's got the manual now too.[/QUOTE]
                          Way to go that should help boost your rep power.
                          Hopefully they can find a helping soul. I am to many hours away(6) or I would give it a look.
