Sharp 507
+ More Options
Posts
  • Vanya
    • Jun 2025
    Sharp 507
    Day kind companions !!!
    Sharp 507-after has cleaned a dirt in the photoshaft block, from piles and also has blown коротроны, there were fat strips on a copy along sheet in width of 2 sm and on all sheet on length-it at blank leaf copying after I have checked up contacts коротронов at device start at loading has appeared the message on toner shortage. When I have pulled out a cartridge I have seen that a photoshaft all black, I дастал and have scrolled it manually, ракель have cleared a toner on it, after assemblage and inclusion the message has repeated also a photoshaft again all black.
    What for a hogwash such prompt please???
    sharp 507:http://www.startcopy.ru/bbs1/msg/1965.htm?35
  • Silvertoast
    • Feb 2010
    • 270
    haveing a hard time understanding ur post, but from what i can gather sounds like u need a new toner roller (its a sponge roller in the toner hopper) if it has gotten hard u will keep gettin a add toner condition, if it has started falling apart u will get way too much toner and will affect copy quality.
      • 22990
      That's as good a guess as any. I am understanding less than 25% of the post.
      Vanya, please try again with shorter sentences. =^..^=
      • pjdbm
        • Sep 2007
        • 360
        I know this machine well and cant make heads or tail of this post.
        • CCS
          • 266
          Sounds like need to replace toner roller to me also, dont forget the toner roller side seals as well...
