AR-M450N fuser issues
  • racer4242
    • Jun 2025
    one unit toner not completely fusing to paper. The prints look fine but if I rub the copies some (not all) toner will come off on my finger
    The other unit wrinkles the paper around every fourth sheet but does fuse the toner.
    I've read about the wrinkle issue with fusers that have been used but the one with the toner smudging looks fairly new. Is there anything I can do here?
  • igi
    • 1507
    hi
    was pressure removed during setup
    check heater bushes
    maybe paper to thick-then increase temperature
    ta
    • bilyahn
      • Dec 2006
      • 1470
      How freely does the fuser move? On the ARM450 series you could run the pressure release engaged or not and it normally did not make a difference. The fuser should not turn freely as a general rule, also look to see if there is a gap between the heat roller and press roller. Can't really think of anything else that wouldn't cause a code also.
      Good luck.
      Bil
        • 22999
        Has your customer been fiddling with the envelope setting levers? About 5 years back, every time I rebuilt one of those fusers I'd take the envelope levers. It's one less thing for the customer to fiddle with. =^..^=
