AR-M280 Error code E7-02
  • verderacer
    • May 2008
    • 158
    From what I can find on the forum this is a Laser unit error where the LD board is not seeing anything. Is this still true for the M280?
    From what I understand the previous Sharp tech replaced polygon mtr, DC controller and PWB board on the maint sheet and its still down.
    Any advice appreciated !
    Ricoh & Microsoft may pay the bills but Un*x saves my ass every day.
    MCSE/CCNE/ENS and other crap...
    • 22996
    You might take a close look at the condition of the ribbon cable from the laser to the PCU. If mistreated, the foil contacts at the ends can be folded over, ripped, missing, incompletely inserted, etc. If that's what you find, I've had very good luck with trimming off the damaged end with heavy shears (as long as you have enough good contact left). Or replace the ribbon cable.
    Or, when the tech was inside the LSU they left a connector undone, or mis-assembled the LSU.
    My guess is that this is tech induced. =^..^=
    • Toner Boy
      • Aug 2007
      • 357
      Could definitely be the cable, otherwise the LSU is probably gonna have to be replaced (unless tech-induced). Make sure you use the AR-M280 LSU, cause the M350, M450 and M280 are all different.
      • Toner Boy
        • Aug 2007
        • 357
        Blackcat, maybe you are referring to AR-M208 ribbon cable??
        • verderacer
          • May 2008
          • 158
          Checked the cable and it toned out ok, all other connections look good and could not find anything that was missing a connection. So I am gonna have to ordera LSU it looks like. Can anyone confim a PN for me?
          Which one?
          DUNT-7093DS15
          DUNT-7093DSZZ
          Thanks for your help !
            • 22996
            Which one?
            DUNT-7093DS15
            DUNT-7093DSZZ
            DUNT-7093DS15 confirms. =^..^=
              • 22996
              Now that you mention it ... probably, yes.
              • verderacer
                • May 2008
                • 158
                Blackcat,
                Hytek tells me this is a board only. Do I need to order the entire assy or do you think I can just replace the board?
                Thanks again for all your help !
                  • 22996
                  Blackcat,
                  According to my reference DUNT-7093DS15 is the laser unit assembly. I would change the assembly. My information does not mesh with your information from Hytek. =^,,^=
