Arm 550 5 1/2 x 8 1/2
  • pontiac
    • 420
    Copier will not let user copy from cassette or by pass tray when 5 1/2 x 8 1/2 is installed in either tray . copier screen message is, Paper in the selected tray cannont be used for the selected mode. Using the adf or placing original on glass same message appears. If i replace paper with standard letter every thing works fine. Any tips? Thanks for replys.
  • ZOOTECH
    Senior member of CRS
    • 3375
    You are loading the invoice sized paper as 5.5x8.5R (landscape) in tray3, right?
    • bdcrandall13
      • Sep 2010
      • 236
      not sure if it applies to this model or not but sometimes having Offset turned on can cause these kind of problems. Try turning it off and see if that helps.
        • 23009
        Exactly! 8 1/2" inches is the minimum media length. Nothing shorter will pass. =^..^=
