Sharp MX-M620N Driver Install Help
  • scomeau1
    • Mar 2011
    • 100
    I'm running Windows XP 32 version and are trying to install the driver for PCL5E or PCL6 for Sharp MX-M620N
    I have downloaded the drivers from Sharp but Windows keeps saying files not found when I try to install them pointing to the directory that the drivers are in.
    Thanks for any help you can give me !
    Scott
  • tmaged
    Owner/Service Manager
    • 1890
    What about running the exe. ?
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • The Otrain
      • 54
      Running the exe is always the easiest way to go for Sharp Drivers. (As noted, he beat me to the punch.)
      • scomeau1
        • Mar 2011
        • 100
        When I run the exe setup program and run standard installation it say's "No MPF Found on network" check to see if power is on. I'm trying to connect via USB cable do I need to run a network cable to the Sharp.
        I was just going to connect it via USB ?
        Thanks for any help !
        • divad2k1
          • Sep 2010
          • 147
          PCL drivers are for network connected copier.
          • scomeau1
            • Mar 2011
            • 100
            USB Drivers
            So then what drivers should I be using for USB only with XP ?
            Thanks for your help !
            Scott
            • igi
              • 1507
              hi
              i think that you gona have to connect via network to print
              on these models if my memmory serves me corectly
              good luck
              • faxman28
                • 435
                When you run the exe, select custom installation and then select connect to this pc,
                • scomeau1
                  • Mar 2011
                  • 100
                  Thanks for teh replys all !
                  I could if run a network cable as I have an open network port - I plan on using Sharp desk so I'm asumming that I need it to be a network printer to do this ?
                  • scomeau1
                    • Mar 2011
                    • 100
                    Now If I connect the Sharp via network cable sould I install both the PCL & PS Drivers. ?
                    I do a lot in Adobe software so do I need the PS driver to print PDF and Indesign files ?
                    Thanks for all your help !
                    Scott
                    • ZOOTECH
                      Senior member of CRS
                      • 3375
                      Scott
                      You will need the postscript option - MXPKX1.
                      • mojorolla
                        The Wolf
                        • 2629
                        Did you extract the file after downloading? This would result in missing files. I am not certain, but I don't think Sharpdesk will work USB. Postscript is an option on this machine, so if you have Mac or want PS drivers, you need the option on the machine. Personally, I like the "add a printer" route; step by step and fewer conflicts. You could also try a crossover cable and connect right to it.
                        • scomeau1
                          • Mar 2011
                          • 100
                          The cossover cable you are talking about goes where ?
                          Thanks Scott
                          • Akitu
                            Legendary Frost Spec Tech
                            • Oct 2010
                            • 2595
                            Crossover cable is referring to a network cable with both A and B type RJ-45 setups... Goes into the network cable slot on the copier.
                            • scomeau1
                              • Mar 2011
                              • 100
                              I have the PCL6 drivers installed via USB cable but now my problem is when I print and go to the setting menu the finisher is grayed out so I can't send the documents to the finisher.
                              Is there some setting to get the print driver to see the finisher ?
                              Scott
