sharp mxm-550n
  • sc3
    • Mar 2011
    • 20
    sharp mxm-550n
    Had the old no turning roller trick, replaced hr gear reinstalled ran to check. the code h3-00 came up reset ran copies came back. check all and everything checks good. this has got to be somthing simple i am overlooking.
    thanks for input in advanced sc3
    • 22991
    I suspect that one or both of the thermistors is crumbling.
    This sort of problem goes all the way back to the Canon NP-6650's. I simple fuser rebuild could turn into a down machine, just by touching a thermistor that has so completely dried out that it crumbles when you touch it. The traces literally fall off of the back of the tiny PWB that the thermistor is mounted on.
    It's also possible that you may have pinched one of the thermistor wires to the frame during reassembly.
    It's going to be related to the thermistors. =^..^=
    • sc3
      • Mar 2011
      • 20
      mxm550
      Thanks BC, You ever had one of those days where the simple things turn into
      tech lighting? even after all these years I'm not going to be shocked.
        • 22991
        I remember that Canon NP-6650 because that fuser actually melted down to the point that I couldn't get the rollers separated. Then (like a genius) I flipper the switch off.
        On the NP-6650 the main drive motor runs for about 2 seconds as part of the shutdown procedure. So not only did I melt down the fuser, but I shattered 3 fuser drive gears. The rollers I was prepared for, not so the gears.
        If I had been a little sharper I would have just pulled the plug. The main drive motor would not have turned, and a couple of rollers & thermistors would have got it back up and running. What a mess. =^..^=
