H4 IN SHARP 53/55 series
  • toniruku
    • Aug 2025
    [Error Code] H4 IN SHARP 53/55 series
    This error occurs when the heating temperature in the fuser unit is not reached during warmup or operation time.
    Causes
    • Heater lamp disconnection or burnt out.
    • Thermistor defective or dirty.
    • Low power voltage in the mains supply.
    • Thermal fuse out or thermostat cutout.
    Solution
    • Check the continuity of lamp, thermostat and thermal fuse and replace.
    • Measure power using voltmeter and wait till it stabilizes.
    • Clear with command 14 ie for Sharp ar5316/5516 series, use
    • #-interrupt-C- interrupt then enter 14 and press copy key.
  • igi
    • 1507
    hi exelent answer
    but what is the question?
    good luck
