sharp ar m276
  • suffer_fly
    • 15
    sharp ar m276
    need help here..
    power supply unit middle fuse blow..
    but when i disconnect heater lamp connector -> fuse ok...
    is it bcouse thermostat is faulty..
    ricoh technician
    • 23008
    Re: sharp ar m276
    Have you metered out the various components of the fuser? This is a very simple fuser. The heat lamp should read 4 or 5 ohms. The thermal switch should be closed, 0 ohms, and the thermistor should read in the 100M ohm range when at room temperature.
    Also check that none of these components is shorted to frame ground. That's what would cause blown fuses. =^..^=
    • suffer_fly
      • 15
      Re: sharp ar m276
      nop im not metered it but confirm no components is shorted to ground..
        • 23008
        Re: sharp ar m276
        If you have not metered out the components, exactly how did you determine whether any of them are shorted to ground? =^..^=
        • Dark Helmet
          • May 2009
          • 847
          Re: sharp ar m276
          Put your meter on diode check so it makes a beeping noise. Put one lead on the frame of the copier and the other on the fuse that keeps blowing. (make sure it's a good fuse and the copier is unplugged). If your meter starts beeping start unplugging things until the beeping stops. What ever you unplugged has a short.
          • JustManuals
            • Jan 2006
            • 9838
            Re: sharp ar m276
            This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
            Paul@justmanuals.com
