AR-235 simulation
  • ramack
    • Jul 2025
    AR-235 simulation
    My Sharp AR-235 is producing an error code, L6-10. From the service manual, it states to run "SIM 61-1"
    Step 1 is below.
    1 Simulation mode selection # → INTERRUPT → C → INTERRUPT
    I press the appropriate buttons, but no response. Any ideas?
    Rich
  • mushy
    • Jul 2011
    • 12
    Re: AR-235 simulation
    L6-10 is a laser motor failure, if it doesnt reset and come into ready after shutting off and on you need a new laser motor some times you can put a drop of oil on the bearing and make it work. Make sure you press the buttons fast enough or it wont accept it, make sure all the keys are working, try #,* c,*
    • ramack
      Yes, I wasn't pressing the buttons fast enough, I started the SIM and waiting for the results.
      • ZOOTECH
        Senior member of CRS
        • 3375
        Step 1 is below.
        Rich
        You must be in the "Copy" mode in order to access the simulations.
        Sorry, didn't see your response.
          • 23008
          So, what result did you get? (It will need the laser unit regardless.) =^..^=
          • lky1978
            • Mar 2009
            • 483
            hi friend, l6-10 can't solve unless u change the polygon motor or lsu unit.no simulation require,just off & on then can reset it
            • ramack
              When I left work, it was in simulation mode, no output at that point. My guess is that it is the motor and not the laser itself. I heard the noise it made when it failed, it literally sounded like it was groaning. I actually thought the sound was one of our people making copies, and they saw something wrong, ha.
              I'm not a copy tech, and none of the manuals (user or service) show where the polygon motor is. One diagram I found showed that it was right below the control panel and/or right above the toner cartridge.
              Have any of you guys torn one of these apart before?
              Where's a good source for Sharp parts?
              Rich
              • JustManuals
                • Jan 2006
                • 9838
                This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
                Paul@justmanuals.com
                • ramack
                  The simulation doesn't produce any output on the display. It does not progress past entering the simulation code. From other threads it looks like the polygon motor is likely to have failed than the laser.
