MX-4501N blowing fuse when fusing unit is connected.
  • sharphead
    • Aug 2009
    • 285
    F1 fuse on the ac board keeps blowing on me Ive tried a new loom which isnt the problem and borrowed another fusing unit which kept displaying heating up, has anyone had a similar problem? I checked the lamps with the multimeter and they arent blown,
  • Ednicarl20
    • Aug 2011
    • 25
    Re: MX-4501N blowing fuse when fusing unit is connected.
    I've encountered this trouble once in MX-4500 but when I replace the HL PWB the problem was solve...
    Hope this can help...
    • bonnie750
      • 302
      Disconnect everything from the AC board. test by switching on. Add connectors one at time until the fuse blows is one way.. F1 protects the AC line to the fuser so I would be looking for a short on the lamp harness in the fuser, has anyone had this apart recently? Does the fuse pop immediately the machine is powered on? Does the fuse pop when the fuser has been removed? this is certainly an uncommon fault on Sharp machines.
      Bill
      • Dark Helmet
        • May 2009
        • 865
        another way to tackle this is unplug the copier, put your meter on diode check so it beeps. Put your negative lead on the frame of the copier and the red lead on the fuse that keeps blowing. It should start beeping when you put it on the proper side of the fuser that is going to ground and shorting. Start unplugging things until the beeping stops. Once the beep stops you know in that harness you have a short.
          • 23010
          I got call from my manager a few years back that I needed to bring a new fuser and power supply out to a customers office.
          What he didn't tell me was that he had rebuilt the fuser the day before. When he hit the switch there was a loud crackling noise, the fuse blew on the power supply, and the breaker blew in the customers panel, knocking out several computers. He had slunk away with his tail between his legs.
          Upon investigation, I found one of the lamp cables pinched to frame ground, the cover melted, and the wire spot welded to that area of the frame. The fuser was saveable, the power supply was not. And the customer asked for me after that.
          All I would have to do is say the businesses name to get a dirty look after that. =^..^=
          • nightshade
            Chromographic Supremesist
            • 158
            I had the same exact happening on an MX-5500, had a screw run through a HL line.
            If you have done any work to the fuser prior to this happening go back and double/triple check your work!
