ARm700U MFP Controller Trouble
  • BMSInc95
    • Sep 2011
    • 66
    [Electrical] ARm700U MFP Controller Trouble
    I have a machine that does not detect when a computer is connected to it. The LED's light up on the PWB but when a USB or parralell is plugged in nothing. Just trying to use as a host based printer. Copying works fine. Any help would be appreciated.
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: ARm700U MFP Controller Trouble
    Usually the USB and parallel ports are for upgrading the flash on this model - have not heard or seen it work as a GDI printer.
    • mojorolla
      The Wolf
      • 2618
      I believe an AR-P19 option is needed for any printing on the U model.
        • 23008
        Agreed. I believe that the USB and parallel are for loading firmware Only on the U models. =^..^=
        • tmaged
          Owner/Service Manager
          • Oct 2008
          • 1887
          Yep these guys are correct. The only time those ports are active is during firmware upgrade. Same with the AR-M355U & AR-M455U.
          Hope that helps !
          -Tony
          www.dtios.com
          Become a fan on Facebook
