Sharp ARM237
  • Jaws
    • Oct 2007
    • 236
    Sharp ARM237
    Got a weird shading and light/faint copy problem when using the platen glass for copying. The ADF copies are fine. And it looks like the shading/light/faint goes away the closer it gets to the right of the platen glass. Take a look at my copies below. Any suggestions, ideas, heck even smartazz coments are welcome.. Thanks in advance.
  • Dark Helmet
    • May 2009
    • 853
    Re: Sharp ARM237
    Check to make sure your optics are stills square. I had a old PB Minolta copier. It was in a military base kitchen and some wizard put a heavy ass bag of something on the corner of the document feeder, broke the welds on the optics frame and the thing twisted slighty downwards. If you took the glass off and ran the optics back and forth you could see the one end going down hill. Their fix was to put their foot on the corner of the stand foot and lift upwards if they had light copies.
    I did have a sharp copier that must of tried to commit suicide at the factory as the one corner of the optics was bent all to hell. Copies off the glass looked ok but when you used the DF it had MAJOR shading. Removing all the plastic covers and putting a ruler on showed about a 1/8 bend in the frame.
    Im going to roll with something bent as there is tons of support for the frame on the right side of the optics so the ADF should look fine. Left side is kinda free floating over there.
    I hope thats smart ass and helpful.
    • JustManuals
      • Jan 2006
      • 9838
      Re: Sharp ARM237
      Paul@justmanuals.com
      • brewster67
        • Jul 2011
        • 167
        Re: Sharp ARM237
        It looks like the mirrors are not moving smoothly. Have you check the optic cables or the optics drive motor.
        • oldrn
          • 166
          Re: Sharp ARM237
          Did you try simulation 1-1 and watch the mirror assembly movement? It is possible to put the wrong screw in to hold down the left glass cover - a long enough screw will hit the lamp assembly. Did you clean & lube the rails? If you have worked on Sharps, you know to watch for Sharp's sharp metal edges on things like rails. Is there any history to go along with the problem - start after servicing, was worked on by someone else, was ok on Friday but not on Monday?
          • toner head
            • Sep 2010
            • 10
            Re: Sharp ARM237
            Make sure rails are clean and try lubricating the bearings in the scan wire pulleys.
            • Jaws
              • Oct 2007
              • 236
              Re: Sharp ARM237
              Thanks for all the suggestions. I went out today for the second time trying to find something bent or out of place or binding. No luck, finally starting messing with the angle of the CCD unit. I got it up and copies are now clear. Had to readjust the leading edge and the skew is a hair off. But, it is ten times better than before. Thanks to all.
                • 23008
                Re: Sharp ARM237
                Congratulations. It's kinda weird though that the CCD would be out of position. I'm thinking that you successfully compensated for some tweaked optics. Again congratulations. =^..^=
                • Dark Helmet
                  • May 2009
                  • 853
                  Re: Sharp ARM237
                  I would agree with Blackcat. Ive never had to touch a CCD other than wipe it off.
                  • DINGO
                    • 661
                    • oldrn
                      • 166
                      Re: Sharp ARM237
                      Sharp's instructions on replacing the LSU are to remove the entire scan unit from the top of the machine. I didn't listen to the olr'n wiser co-worker who always assumes there is an easier way, is a don't read the manual kind of guy, and I removed the scanner section, frame and all. When I put the scanner back, I believe I did end up with an odd CQ problem, probably from a twisted scanner unit and I believe I may have resolved it through CCD adjustments. Needless to say, I found an easier way to replace the LSU after that.
                      I also believe I may have adjusted CCDs on this series when I first started seeing E7-11 (?) errors that could not be resolved with white sheet placement. I would not suggest CCD adjustment to anyone with a short temper.
