MX-3501
  • Vesigoth
    • Mar 2008
    • 133
    [CQ] MX-3501
    Ok this is weird... copies made through the adf or from the glass come out with what looks like "slashes" or "/" all over the copy in perfect rows and evenly spaced. These "slashes" are made of 5 individual dots. This only happens on copies. Prints and faxes come out fine. This pattern looks like something that the machine might generate if it were in some kind of test mode. The problem appears in color and in black mode, and the dots that make up these "slashes" are black never in any other color. If you've seen this, please advice. Thanks
  • JustManuals
    • Jan 2006
    • 9838
    Re: MX-3501
    Paul@justmanuals.com
    • mojorolla
      The Wolf
      • 2639
      Re: MX-3501
      Sounds like the CCD might be going as prints are OK. You can run shading in SIM 63 to test the CCD.
      • igi
        • 1507
        Re: MX-3501
        hi ther you may have a faulty memory
        try to clean or check contacts,or replace
        good luck
        • Vesigoth
          • Mar 2008
          • 133
          Re: MX-3501
          Thanks for the reply mojorolla, but which SIM 63-?.
          • Vesigoth
            • Mar 2008
            • 133
            Re: MX-3501
            good luck
            Thanks for the tip igi, should I clean and reset all memory dims or do you have a specific one in mind?
            • Akitu
              Legendary Frost Spec Tech
              • Oct 2010
              • 2595
              Re: MX-3501
              63-2 for forced shading, my only experience with memory and prints was related to a post script error, I never did find which RAM DIMM was the cause, but did replace all of them and had the issue clear up after, so unfortunately I have no advice to give on bad memory other than "Change it all!". My issue was non-consistent and random at best, so I was unable to conclusively identify which RAM DIMM was responsible for my printing error. Good luck with yours, do you have sample prints?
              • ZOOTECH
                Senior member of CRS
                • 3378
                Re: MX-3501
                Does it put those marks on the 2nd side also (CCD in DSPF)? If so, it might be the Scanner Control pwb, the DSPF memory pwb, or the Scan In pwb. If not, then the CCD in the scanner area might be the cause, or the memory sticks as others have mentioned.
