mx 2700n fuser jam problem
  • bherchek
    [Jamming] mx 2700n fuser jam problem
    z-fold jam occuring in fuser, did have a code but cleared with sim 14, still jamming, customer said last tech to look at machine said jamming is caused by flat spot on upper fuser roller, yes there is a flat spot, any ideas
  • brewster67
    • Jul 2011
    • 167
    Re: mx 2700n fuser jam problem
    I would check the fuser pawls and make sure there is not toner build up on entrance guide, pull the fuser and manually try to run paper thru, if it will go thru with pressure released but has problems with pressure on, I would change out the rollers
    • bonnie750
      • 302
      Likely to be the flat causing the problem though if it jams every copy a tripped thermostat can cause the same thing.
      Bill
      • Sam Tofu
        • Dec 2007
        • 130
        Not certain on the 2700 but with the 3500,3501 and 4500 fusers (different than the 2700/2300)
        It is important to do the fuser pressure release if the unit is sitting for awhile. WE had customers not using their copier-one a school, another on long vacation - they didn't head the user manual warning. Both got flat spots from sitting a number of weeks.
        However, for both, we ran aging and with a little effort the flat spots worked out.
        In both these cases, at first when the copier would go through warm cycling it would sound like a car with a flat tire - bump bump bumpity bump.
        • bilyahn
          • Dec 2006
          • 1470
          Use the MX270HK if you are going to rebuild the fuser. Has everything in it and the new bearings for this unit. Depending on how old the machine is this unit had a few problems with the fuser.
          Good luck.
          Bil
          • BMSInc95
            • Sep 2011
            • 66
            The heat roller is the one that gets flat spots. Also if you take the fuser apart be careful when you put it back together there is a small metal roller that rides on the press roller that pivots and can get put back in the wrong spot keeping the press roller from turning.
            • bonnie750
              • 302
              The mx2700 doesn't have the cleaning roller. the mx2600/3100 have this which does get trapped, It's one of those you only
              do once
              Bill
              • mojorolla
                The Wolf
                • 2627
                do once
                Bill
                On the 2600/3100 I remove that "cleaning" roller. It does nothing but gunk up and damage the roll it is supposed to clean.
                • bonnie750
                  • 302
                  Likewise! throw them in bin. They stopr rotating and damage the roller surface.
                  Bill
                  • BMSInc95
                    • Sep 2011
                    • 66
                    Okay, no "cleaning" roller on the 2700. probably flat spot on heat roller.
                    • vic554
                      the 23/2700 gets flats spots on the fuser roller after a while and especially went sitting idle. If the m/c is sitting idle for more than a few days its best to release the pressure off the rollers by pulling up the pressure levers.
                      • ZeusGT
                        • 271
                        do once
                        Bill
                        Took me a couple of hours to figure that one out. Like you said, once you do, you'll never forget it. Ha!
                        CompTia A+ Certified
                        CompTia Net+ Certified
                        CompTia Server+ Certified
                        CompTia Project+ Certified
                        OP Scanshare Certified
                        • Akitu
                          Legendary Frost Spec Tech
                          • Oct 2010
                          • 2595
                          Was necroing a 3 year old thread entirely necessary for this?
                          • ZeusGT
                            • 271
                            Really? Was that comment really necessary?
                              • 23010
                              Easy gentlemen. Fisticuffs outside, please. =^..^=
