SHARP ARM 350 JAM
  • pontiac
    • 420
    SHARP ARM 350 JAM
    Copier is jaminig as it exits the fuser and throws H5-01 code after 5 jams. I replaced fuser assembly and cleaned the turn around unit. I checked the sensor arms for movement and no binding. When i tested copier all 50 went thru with no jams then customer called after i left and copier started jamming again same area. Any thing else i need to check or need to replace please let me know. Thanks for replys.
  • gwaddle
    • May 2009
    • 782
    Re: SHARP ARM 350 JAM
    Knowing the jam code would help, but chances are pretty good you'll end up replacing the delivery unit. I see that you cleaned it, in my experience that only delays things. Replacing the unit is usually the best way.
    I know I should be ashamed of myself. Strangely though, I am not.
    • bonnie750
      • 302
      Replacement is usually the fix, though if the exit rollers have not been modified this will cause intremittant jamming. The material the early rollers were made from tends to crack away from the core which carries the axle. the lead edge of the paper catches the cracks and jams occur.
      Bill
        • 23010
        If they're H5-01 codes, its POD_1N jams, and I agree about disintegrating exit rollers. =^..^=
        • pontiac
          • 420
          Sorry everyone, yes it did come up with the jam indicating POD 1. Thanks for the feedback.
          • Nachoman4life
            • Oct 2007
            • 212
            500K is a good life for a switchback/delivery unit. IMOHO
            Where the heck is my spring hook?
            • SpringHook
              Also check the reverse gate any wear & tear on the teeth or down and up mechanism
              check for drive on all those roller b4 the POD 1 sensor bearings may need some cleaning and grease
              • jcontractor
                • Aug 2010
                • 247
                Did you solve your jams problems?
