Have an AR-C 170M with H5-01 code
  • EIS
    • Jul 2025
    [Jamming] Have an AR-C 170M with H5-01 code
    Hello All,
    The Aircraft museum I belong to as a volenteer has been given a Sharp AR-C 170M to use and it has constant H5-01 codes.
    Am a Xerox Wide format plan printer tech for the last 23 years, before I drive 100 km to the museum to have a look at it as I dont have a manual for this machine yet is it something that is going to require the fuser module replaced ????. They dont have a lot of money to buy parts.
    Any advice is appreciated.
    Cheers
  • igi
    • 1507
    Re: Have an AR-C 170M with H5-01 code
    hi
    h5-01 paper jams in the heater unit
    you need to go and see if you need parts
    seperator claws friends of santa may need to be replaced or the rollers
    go see and if all is well reset with sim-14
    good luck
    • EIS
      Thanks for the reply,It is appreciated.
      It will have to wait till next time I am down there working on the PBY Catalina and will look at it then.
      If you are interested in aircraft look at Historical Aircraft Restoration Society Inc
      cheers
        • 23008
        You won't want to spend a lot of time or money on this Bear. It was well named.
        It is expensive to operate and will be troublesome. Most of the Sharp guys will agree that they were very glad when these machines were replaced with Pastel or C-Jupiters. =^..^=
        • JustManuals
          • Jan 2006
          • 9838
          Paul@justmanuals.com
