Check stapler position or stapler jam
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1868
    I have an FN7 on an MX-M450N that had an F1-06. I checked everything out, but now I get this message on the display when I try to staple. They have a couple of these since it's in a hospital, so I went to another one & grabbed the whole staple unit frame section & swapped them. The non working machine doesn't work with the other unit, so I've pretty much ruled out the staple unit. I've checked the alignment with the blue dot & gear. Any ideas where else to look ?
    Edit to add I'm not getting any error codes now.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • 22997
    Re: Check stapler position or stapler jam
    Apparently you didn't check quite everything if it still's not working. (Sorry. i couldn't resist.)
    The AR-FN6 finishers were a lot more troublesome, especially regarding stapling. F1-87 codes were very common.
    The AR-FN7 finishers were pretty reliable. The F1-06 is slide motor trouble (I'm sure you already know that).
    You can test the slide motor in simulation 3-3-6, Start to execute, System Menu to stop.
    I've never experienced any problem with this motor, but it drives the stapler forward/backward. It could be something as simple as lubrication (greasing the tracks), or an obstacle in the stapler's path. The manual lists 1) repl motor M8, 2) repl finisher controller, but I don't think it will come to that.
    • tmaged
      • Oct 2008
      • 1868
      That's why I'm lost on this one. I get no error code. When I go into sims, I can't run anything in the finisher section. The slide motor is actually mounted on the whole staple carriage unit, which I swapped with the other machine on location. I swapped staple cartridges also. Scratching my head !
      Hope that helps !
      -Tony
      www.dtios.com
        • 22997
        I suppose there may be a dead short somewhere, killing one or more voltages in the finisher, but there won't be an easy way to track it down.
        If the 24vdc is present at the finisher controller, it makes sense that the finisher controller or PCU PWB is defective. At finisher controller check CN1-1 (+24 vdc) to CN1-3 (ground), and CN2-1 (+24 vdc) to CN2-3 (grd). If voltages are absent, power Off and unplug finisher. If voltages return (CN20-3 to 20-2, CN20A-2 to CN20A-1) you've got a dead short somewhere. If they don't return you may have a dead power supply and a dead short, or just a dead power supply.
        I've replaced a few power supplys on Tigers and Jupiters. =^..^=
