AR M450N - Finisher Trouble
  • tmlysek
    Sharp AR M450N shows error message
    "CODE F1 - 87 FINISHER TROUBLE"
    I see similiar posts here. Is this a common issue? What is the fix for this copier?
    Thanks in advance.
    • 23010
    Is it an AR-FN6?
    For the AR-FN6:
    First choice) Replace the (4) stapling tray pressure arms (LSTPP0357FCZZ). After you replace them you'll see that the tips get worn down, and wedge into place so that the black support plates cannot move out of the way of the stapler. The black plates look warped, but they aren't (I should say they always look like that).
    They are fairly easy to get to. You do have to remove the finisher from the copier. Remove the front and rear covers. Open the right door. Pull the pins that retain the door. From there you'll see the arms. They can be changed with a little maneuvering.
    • tmlysek
      Thanks, I really appreciate the quick response. After a little investigation, I ran the sim test and it too gives the error code F1-87. The info I have says it's a problem with the front staple rotation motor. Is this in conflict with what you are suggesting? I don't have the finisher diagram yet so I can't see what you are discribing.
        • 23010
        AR-FN6 or AR-FN7
        Yes, it is a stapler rotation error. The stapling tray pressure arms become dull at the tips, so when the stapler attempts to move into position to make the staple it cannot move the guides out of the way. No conflict.
        You still haven't answered. Is it an AR-FN6 or AR-FN7?
        • tmlysek
          AR-FN6
          • tmlysek
            finisher trouble
            The fix you recommended as "first choice" is to replace the four pressure arm pins in the lower alignment tray area. This area of the copier is never used. Is it still moving and subject to wear? Or is there a likely second or third choice?
              • 23010
              The stapler must home every time the machine is powered Off/On.
              2nd Choice) Clip overtight wire ties to the stapler rotation home position sensor.
              3rd Choice) Shake down the stapler to its bottommost position (wherever it settles is fine). Adjust the flag that triggers the stapler home position sensor. If I remember correctly its the narrow slit in the flag.
              Both of these are much less likely.
              If you have a better idea, go for it.
              • rastyp3c
                • May 2009
                • 15
                would this also apply to ARm280U models?
                  • 23010
                  If it's an AR-FN6... Yes.
                  • rayjeek
                    • Jun 2010
                    • 239
                    I have had this several times and there is a bulletin on this F1-87. It only means that a spring is fallen off from the black plate acting as a gate to allow the staple head to move back and forth. You have to take the finisher out of the MFD before you can refit the spring. Make sure to apply some grease to the plates before re-installing the finisher. Good Luck.
                    • OMD-227
                      The times I've seen this, it was the spring actually breaking. The spring part number was changed years ago with a different shape, so I doubt you'd have that issue on a newer model such as the ARM208. Go with what the guys are saying here. If the spring has broken, I'd be very surprised.
                      • rastyp3c
                        • May 2009
                        • 15
                        is there older and newer model of those finishers?
                        Becuase the one I was looking at had gray plates and in order to get them out I had to loosen the lift motor assy so I can slide a shaft that was going through the whole width of the finisher. after I got those things out it started just fine and has not had a problem again.
                        I do have another question though. other problem is that compies are not aligned with originals. I downloaded service manual ( from nodevice) and there is nothing mentioned about that kind of problem. Working on some other copiers I think it's a document scanner calibration. I checked but I can't seem to find anything on it anywhere. Any Help?
                          • 23010
                          This post will help you out:
                          http://www.copytechnet.com/forums/sh...arp-450-a.html
