AR-407 Toner Supply
  • mas1683
    AR-407 Toner Supply
    I'm having problems with an old Sharp AR-407. The machine keeps displaying "Toner Supply is low" and about once a week somebody adds toner even though the tray is full. It has gotten to the point where I tell the people to cycle the power to get rid of the message that would force them to add toner.
    Can anybody help me clear up this problem?
    Thanks,
    Mark
  • pjdbm
    • Sep 2007
    • 360
    Are you using OEM Toner? Is the toner fresh? are they shaking it well?
    May have to vacuume out and start fresh dev. and toner
    • mas1683
      The toner is new as of about 3 months ago (Sharp AR-400NT) and were well shaken before putting in there.
      I might try the cleaning trick and see what I come up with.
      Thanks,
      Mark
      • johnbla
        • Apr 2005
        • 94
        I think you are missing the point, it's Not just a matter of 'a cleaning trick', but of 're-Value-ing' the Developer and checking Tonerflow....
        Your problem may not be solved by this proceedure....
        This model will report 'add toner', when the copy image has been over the 8% of standard Black coverage for more than 20-40 continuous copies ...the Machine cannot compensate for the extra Toner being drawn from the Dev Tank and believes that the Toner supply has run out..
        regards
        John
        sigpic
        " The Game never ends..When your whole World depends..On the Turn of a Friendly Card..."
          • 23010
          johnbla is right. They must be running some pretty heavy fill originals. If you can verify this for sure, I have an old Mita trick for you:
          On the Mita DC213 The machine was unable to keep up with toner usage. Our answer was to take needle-nose pliers and create small divets (or valleys) in the foam roller in a grid pattern (so it feeds evenly) to increase the the amount of toner being fed through. Now I mean small divets (1 to 1.5mm), not any bigger, and maybe a total of 25 or less on the whole roller evenly spaced. Maybe a pointed object might work better to perforate the roller on the Sharp.
          If you start getting F2-00 or F2-02 its dumping toner in too fast. That's why I said make sure that they're running heavy fill. You can create a secondary problem. And you can't put the foam back, so if it doesn't work you'll have to install a new foam roller & seals.
          All this being said, its fairly unusual for a customer to deplete the toner as fast as you describe on a Cougar. I know of only (3) occasions, and they were all real estate agencies copying pictures of homes.
          • johnbla
            • Apr 2005
            • 94
            Cat
            I have 5 churches with Cougars and every Friday, when running off the 'Order of Battle' for Sunday, they regularly have this problem... caused by excess coverage on their pamphlets.
            I have tried various methods and have yet to find one that fits all occassions......
            So I try to 'train' customers..... if they want the 'extra coverage' they must be prepared to do smaller runs ~ 40 max and to cycle the power to re-value if required..
            regards
            John
            sigpic
              • 23010
              johnbla,
              Why don't you take a try at perforating one of those foam rollers. I really think it will work for you.
              • pjdbm
                • Sep 2007
                • 360
                I would put the thing in toner save mode before I touched that foam roller.
                  • 23010
                  The resulting loss of fill will be a hard sell to the customer. Toner Save looks like crap.
                  • choicecopyguy
                    • Mar 2006
                    • 111
                    As touchy as those foam rollers are I'd have to be in a hard spot before I tried it, although I will keep it in mind.
                    • johnbla
                      • Apr 2005
                      • 94
                      Cat
                      I have to agree with Choice, I would not mess with the sponge roller....
                      Although I did try 4 longitudinal cuts into it, as a trial for the one of Churches, but had too many F2's when they were doing 'normal' copy.
                      Also adjusted/varied the range of the DevConc 'off target percentage' to give a bit longer before 'add Toner', but gave grief in PCQ..
                      They have to live with it... or Up-Grade to something that can deal with it....
                      regards
                      John
                      sigpic
