Sharp AR-M237
  • lenovos
    • Oct 2012
    • 140
    [CQ] Sharp AR-M237
    Hi I have a Sharp AR-M237 Pulling excesive toner from the center of the DV unit. The seal is coated with toner and it pulls toner into the corona unit. I have replaced the dv unit mc unit and transfer roller. The problem always returns and seems to affect about 2 inches right in the center of the developer unit. Thanks in advance.
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    Re: Sharp AR-M237
    What can happen occasionally is the mylar seal will curl in on itself and dig in just enough to start lifting developer straight off the roller. I've removed the seal in the copiers that were having this issue and it has resolved it.
    Worst case scenario is that developer gets into the back in the clutches, the machine has to be broken down and vacuumed out, as well, each affected clutch must be cleaned individually or replaced.
      • 23009
      Re: Sharp AR-M237
      I'll confirm that. I've always replaced those seals, but removing it works too. At our dealership the problem was other techs adding new seals over the old seals. You've got to peel off the old one and clean off the adhesive before installing a new seal. DVC Seal: PSEL-0025QSZZ
      • Akitu
        • Oct 2010
        • 2595
        Re: Sharp AR-M237
        Oh my. At what point does common sense factor in there? One would hope they would have been attentive enough to notice that just overlapping them would accomplish far less than removing the original...
          • 23009
          Re: Sharp AR-M237
          Oh my. At what point does common sense factor in there? ...
          Common sense? It seems to be in short supply. I'll order up a gross of it, just tell me where to it comes from. =^..^=
          • lenovos
            • Oct 2012
            • 140
            Re: Sharp AR-M237
            I started out with a brand new dv cover and i understand about cleaning off the old seal. I have had problems with the machines dusting up without the seals.
            • lenovos
              • Oct 2012
              • 140
              Re: Sharp AR-M237
              I have replaces the seals a couple of times. Every couple of weeks it seems to dust up
              • lenovos
                • Oct 2012
                • 140
                Re: Sharp AR-M237
                The part # I have is PSEL-0132QSZZ
                • Akitu
                  • Oct 2010
                  • 2595
                  Re: Sharp AR-M237
                  I've had continued problems as well, hence why I removed the seals. If you're still getting problems with pulling developer, then your drum may be worn, as you've said you changed the charge grid and transfer roller. Maintenance cycle on the 237 is 75k, which involves drum, dev, cleaning blade and charge primarily, have you replaced the drum unit recently?
                  • lenovos
                    • Oct 2012
                    • 140
                    Re: Sharp AR-M237
                    I have replaced all of the consumables. I have not replaced the door, laser, or pwer supply. I know that on some of the 275's the door would warp an they would pull developer.
                    • JustManuals
                      • Jan 2006
                      • 9838
                      Re: Sharp AR-M237
                      Paul@justmanuals.com
