lines on copies sharp mx-m904 need help
  • Lopakadee
    • 11
    [CQ] lines on copies sharp mx-m904 need help
    i have a mxm904 sharp. the first copy comes out nice but the rest of the copies are coming out with dots on them almost in a perfect line. but not side to side but top to bottom. PLS HELP
  • bilyahn
    • Dec 2006
    • 1470
    Re: lines on copies sharp mx-m904 need help
    I would check the fuser. Normally I get more that just dots at about 35 - 50 mm from the lead edge. Fuser heat roller will look okay, press roller may or may not be wrinkled. Where are you at in the PM cycle?
    Good luck
    Bil
      • 23008
      Please attach a scan of the quality problem. =^..^=
      • mxm
        • Feb 2011
        • 37
        Hi
        we have had something like what you describe dotted lines top to bottom a3.
        Our tech changed the dm cleaning blade
        • mxm
          • Feb 2011
          • 37
          Here is an example of our fault
