i have a mxm904 sharp. the first copy comes out nice but the rest of the copies are coming out with dots on them almost in a perfect line. but not side to side but top to bottom. PLS HELP
lines on copies sharp mx-m904 need help
Re: lines on copies sharp mx-m904 need help
I would check the fuser. Normally I get more that just dots at about 35 - 50 mm from the lead edge. Fuser heat roller will look okay, press roller may or may not be wrinkled. Where are you at in the PM cycle?
Good luck
Bil -
Please attach a scan of the quality problem. =^..^=If you'd like a serious answer to your request:
