I have an AR M450 that prints test pages fine. The problem occurs when you attempt to make copies. The page comes out blank. As stated it prints fine, no issues with laser, drum, developer, etc. Scan lamp and mirror drive operate with no problems. I am thinking either CCD or main board, but would like other opinions before we start spending money. Thanks.
ARM450 prints fine, copy output blank
Re: ARM450 prints fine, copy output blank
Try executing a shading adjustment with sim 63-2, also make sure the scanner reference plate is cleaned too obviously.
Reseat connections from the scanner to the copier as well.Cthulhu for president! Why settle for the lesser evil? -
danceswrabbits
How about 2 sided copy? since side 2 is copied by the cis instead of the ccd on 2 to 2.Comment
Second be cautious with the scanner board. There is just a bare metal plate under the scanner board and if you press upward even slightly you'll short out the scanner board. I would tape a transparency to the inside of the metal base to avoid damaging boards. I'm thinking this is the most likely cause.
=^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
