ARM450 prints fine, copy output blank
  • jrob416
    • May 2011
    • 112
    [CQ] ARM450 prints fine, copy output blank
    I have an AR M450 that prints test pages fine. The problem occurs when you attempt to make copies. The page comes out blank. As stated it prints fine, no issues with laser, drum, developer, etc. Scan lamp and mirror drive operate with no problems. I am thinking either CCD or main board, but would like other opinions before we start spending money. Thanks.
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    Re: ARM450 prints fine, copy output blank
    Try executing a shading adjustment with sim 63-2, also make sure the scanner reference plate is cleaned too obviously.
    Reseat connections from the scanner to the copier as well.
    • danceswrabbits
      How about 2 sided copy? since side 2 is copied by the cis instead of the ccd on 2 to 2.
      • kronical
        Kronic Copier Ninja
        • Nov 2009
        • 230
        This will definitely eliminate the mainboard from the equation if 2nd side works...
        There is also a scanner board in there too.
          • 23008
          First power off, and re-seat scanner connector. Don't start wiggling connectors with it live. You'll blow boards.
          Second be cautious with the scanner board. There is just a bare metal plate under the scanner board and if you press upward even slightly you'll short out the scanner board. I would tape a transparency to the inside of the metal base to avoid damaging boards. I'm thinking this is the most likely cause.
