ar-m700 toner issue
  • igrafix
    • Jan 2011
    • 17
    ar-m700 toner issue
    I was having issues with toner not adhering and being able to be rubbed off the sheet, so I replaced the complete fuser and I still have the same problems. Any thoughts on what next? Thanks.
    • 22930
    Re: ar-m700 toner issue
    What type of media? What media settings? =^..^=
    • igrafix
      • Jan 2011
      • 17
      doesnt seem to matter at all, I have tried bond, color copy, coated, same results. even reg text will come off.
      • Silvertoast
        • Feb 2010
        • 270
        did u loosen the pressure screws so the pressure is applied. 2 screws on each side. when they are tight the rollers arent pressed together. when loose there is pressure
        • ZOOTECH
          Senior member of CRS
          • 3374
          Correction, one screw each side - this is most likely your trouble.
          • Silvertoast
            • Feb 2010
            • 270
            sorry that was a typo on my part. tryin to watch a movie and type at the same time. lol meant to say 2 screws one on each side
            • ZOOTECH
              • 3374
              I know you knew, my correction was to save time for anyone looking for the 'second' screw.
              • igrafix
                • Jan 2011
                • 17
                Thanks guys that is what was wrong, looked at the old fuser, those screws were tight too.
