White streaks ARM257
  • mattguthrie
    • Jan 2012
    • 35
    [CQ] White streaks ARM257
    I have this ARM257 with the streaks shown in Pic. It occurs on internal prints so I have ruled out the scanning system. I have done the following to address it with no success:
    >Replaced drum & developer
    >Replaced developer & process assemblies(including charger)
    >Replaced power supply & high voltage boards
    >Replaced side door w/transfer assembly
    >Replaced LSU
    >Inspected and cleaned process assembly contact springs in back of copier
    Any suggestions and insight will be appreciated.
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    Re: White streaks ARM257
    Clean your laser slit glass. Remove the dev unit and drum, and clean straight up. Else the problem could be something stuck in your cleaning blade...
    • mattguthrie
      • Jan 2012
      • 35
      Thanks for reply. As I previously stated, the problem happens on internal prints too so the optics can be ruled out. The reason for the sky shot example was to exaggerate the defect. Also, I replaced the process unit assembly in which I installed a new blade and new drum to no effect. The developer unit also had new material in it.
      • Akitu
        • Oct 2010
        • 2595
        I said nothing about the optics. Re-read my post.
        • mattguthrie
          • Jan 2012
          • 35
          My mistake. I replaced the entire laser assembly and didn't see anything else that might occlude the beam. Am I overlooking something else in that section of the printer?
          • Akitu
            • Oct 2010
            • 2595
            Run a few of those internal prints, and open the door as the paper is passing by the drum. Look at the drum and see if there's a void spot in that location, if the toner is even getting onto the drum. You say you replaced developer, but did you look at the unit itself? I've had bits of paper lodge themselves in the doctor gap of the mag roller and sweep the dev right off the roller.
            • mattguthrie
              • Jan 2012
              • 35
              There is no toner on the drum so what you say makes sense. I don't recall having looked under the blade w/my own eyes. I'll check.
              • divad2k1
                • Sep 2010
                • 147
                My guess would be the dv cover/seal getting in the path of the laser beam. Had this last year and took me a few calls to find it out.
                Correct me if im wrong but i think the cover doesnt come with the dv unit .
                And the seal doesnt come with the cover.
                  • 23010
                  Correct on both points. And I agree about a warped upper cover or upper seal. =^..^=
                  • mattguthrie
                    • Jan 2012
                    • 35
                    The seal is the culprit. I appreciate everyone's assistance. Thanks
