Sharp MX-M450, L4-02
  • copyman
    Owner / Technician
    • Sep 2005
    • 4607
    I know this is for drum motor lock. Anything common that would cause this? Customer said machine was working good then code came up all of a sudden.
    Thanks in advance
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: Sharp MX-M450, L4-02
    Thanks in advance
    Blade flip,or toner buildup in waste toner augar.
      • 22996
      On the Tigers, it's quite common to get a seized up main drive assembly, or main charge arcing from the HVT lead (which is part of the main drive assembly). I don't think it's ever been the main motor. =^..^=
      • JustManuals
        • Jan 2006
        • 9838
        This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
        Paul@justmanuals.com
        • copyman
          Owner / Technician
          • Sep 2005
          • 4607
          Found the waste toner packed in augar which broke the small idler gear stud off. Had to order a new process unit.
          Of course the customer said it was making a noise for last month! Machine is under contract and they always call me for every little thing but not for this loud noise! Now it will cost me $150 for process unit because they thought it wasn't a problem making the noise!
          Gotta love these customers some times......
          • foudl
            • Mar 2010
            • 138
            How many copies on this machine?,i had to change the main drive assembly on one of mine but it was over a million copies.
            • MHeon71
              • Oct 2008
              • 489
              I would agree with all of the above comments and to check into the bulletin MFP-TB-290. They changed the tension of the DV drive spring.
              • DINGO
                • 661
                If the copier as many copys the dv unit can give this code to
