MXM 453N lines when scanning to network
  • rocky_biskit
    • Jun 2009
    • 76
    [CQ] MXM 453N lines when scanning to network
    Customer says lines are randomly appearing when scanning to network. They have complained of lines when printing as well but not as much when scanning. I cleaned the optics as well as the laser unit and yet the lines are still randomly appearing. One of the periodic lines will be almost like a "dot matrix" type line about a quarter inch in thickness transversing the entire length of the page, while the other random lines appear to be your average dust in the optics scenario. At first I was leaning toward the laser as being the problem, but and correct me if I am wrong, the laser is not used when scanning. Has anyone seen this before? Help is greatly appreciated as this is one of our bigger accounts located in Boston and being a small company, we would like to keep them happy.
  • danceswrabbit
    • Dec 2013
    • 65
    Re: MXM 453N lines when scanning to network
    I suspect your problem is optics. Have you looked under the black plastic cover on the ccd? seen some spider webs do some strange things. Also if you scan something 2 sided are lines on both sides?
    • rocky_biskit
      • Jun 2009
      • 76
      Thanks! I forgot to mention, he did complain of double sided doing it more than single side.
      • rocky_biskit
        • Jun 2009
        • 76
        btw ... I will check the black box but I dont think that would cause a print job to do the same thing.
          • 22963
          Did you clean the surface of the CIS and white reference also? It also can get dirty, and would explain intermittency, since not all images are two sided. =^..^=
          • danceswrabbit
            • Dec 2013
            • 65
            I misunderstood, The random lines printing is likely main charger shorting. On the scanning have you cleaned the set of optics in the feeder (that does the back side)? I think the main charger is in the mx-503mk kit.
            • harleyrider
              • Oct 2011
              • 348
              you probably have 2 different problems. Problem when scanning is probably optics either in scanner or doc.feeder and you are right the laser is not used when scanning. The lines when printing or copies is most likely corona.
              • ZOOTECH
                Senior member of CRS
                • 3374
                It's most likely a DiMM problem on your MFP pwb. The SCN control pwb could be at fault for the scanning issue.
                • mojorolla
                  The Wolf
                  • 2571
                  -Check adf slit glass for scratches. Trying scanning in color and see if the lines change to blue. If so, you have an etch in the slit glass.
                  -Try changing the file format and/or compression in the image send settings.
                  -If it has a DSPF, check the second side CIS as mentioned.
                  I think I have a new catchphrase.
                  LTTL....Leaning Towards The Laser
                  • harps05
                    Field Service Engineer
                    • Mar 2012
                    • 111
                    Just a query, if they're viewing the scanned docs as a pdf, check what version of Adobe they're using. The were problems with a particular version year, which would cause what looked like digital interference. As a test, scan a document as a .bmp or .tiff or similar and view it as an image and see if the lines are still present.
                    • rocky_biskit
                      • Jun 2009
                      • 76
                      Thanks, I will have the customer try that. You didnt mention which version, so I will assume that if they download the latest version that should either fix or eliminate the problem.
                      • mojorolla
                        The Wolf
                        • 2571
                        Adobe Reader X (10) was known to cause issue. I think they are version 11 now.
