ar m237 f6-10, f6-88 codes
  • walterman
    • 196
    Re: ar m237 f6-10, f6-88 codes
    I went back to the customers location and checked to see is the oulet was properly grounded, I checked the two -wire fax line, and also performed a sim 66-2 to put all the soft switch settings back to factory. The reason I was not hearing a dial tone from the mfp.... the company that sold them the box did not install a speaker, an over sight on my part, nonetheless, the fax seems to be working so far at this point (fingers crossed). Thank you, for all the input and knowledge, I do appreciate it.
    • lky1978
      • Mar 2009
      • 483
      faxman right.
      My customer bought a phone cable with wrong way wire seated. Always show line use when plug in.
      • Akitu
        Legendary Frost Spec Tech
        • Oct 2010
        • 2595
        Well that's a first, I can't say I've ever heard of someone not having installed the speaker before. I hope you ream them out good and hard for wasting your time by not installing a speaker and causing you and your customer to panic.
          • 23007
          #19
          I have never neglected to install the speaker, but on some of the early facsimilie which you could not turn off the volume I have snipped the speaker wires, upon customer request.
          • walterman
            • 196
            #20
            Agreed, black cat, I have done the same as well but have always installed the speaker... especially if you have the option to turn it off via the control panel.
            • walterman
              • 196
              #21
              Plus, I have to add the fact that I should not have overlooked speaker was never installed; hence, no sound. Duh!! I just take the basics, or lack there of, for granted sometimes.
              • ZOOTECH
                Senior member of CRS
                • 3375
                #22
                When a customer is annoyed by the speaker, I would first try covering the speaker holes with a couple layers of tape to muffle the sound before un-plugging the speaker or cutting wires (but the speaker was always installed).
