mxm620 black copies intermittent
  • Silvertoast
    • Feb 2010
    • 270
    [CQ] mxm620 black copies intermittent
    I have a mxm620 that is making intermittent black copies. I know this is due to lamp not coming on and there is a tsb mod for it. The mod has already been done to this machine. I'm thinking my next step is going to be the scanner pwb. Just looking for additional input. Copier was not doing this on arrival. Tested scan lamp in Sims repeatedly with no issues.
    • 22999
    Re: mxm620 black copies intermittent
    Other possibilities for flickering lamp are:
    Cracked lamp harness
    Flickering Xenon lamp
    Cold environment
    Inverter PWB
    What's the mod? =^..^=
    • Silvertoast
      • Feb 2010
      • 270
      not really flickering, it just does not come on sometimes causing black copies. have seen this before and the mod fixed it. but its already done on this one ( either by tech or factory?)
      tech bulletin MFP-TB-238
      • bilyahn
        • Dec 2006
        • 1470
        Check your ribbon cable. Had one do this after the modification and after swapping out components realized the only thing left was the ribbon cable. Cable looked perfectly fine but would randomly put out black copies.
        Good luck.
        Bil
        • tmaged
          Owner/Service Manager
          • Oct 2008
          • 1869
          We have one doing it also. It's close to 4 Million copies, so sales is trying to get it replaced. Cycling power seems to take care of it for a while, then it recurs.
          Took me a while to figure out the lamp wasn't coming on because the customer would shut it off when it started, then it worked fine when I got there. Ours has the mods & a new inverter PWB, but that hasn't fixed it. If it was the ribbon cable, cycling power wouldn't stop it, and it would do it more frequently I would think.
          Seems like it would be a ground issue, but not sure where else to go either.
          Hope that helps !
          -Tony
          www.dtios.com
          Become a fan on Facebook
          • bilyahn
            • Dec 2006
            • 1470
            I agree. I didn't think it could be the ribbon cable either but it's a quick and cheap item to replace and if you have any ARM550 series machine in the shop you can just swap the cable.
            Bil
