AR-5015
  • Polo-022
    • Sep 2007
    • 486
    AR-5015
    Soon after drum/developer/blade replacement the LSU seal glass over DV unit becomes dirty from toner spillage and copies are faint. DV unit also has a layer of toner at the top. I have to clean both every 100 copies. I have done many replacements but i see this for first time!! What's the cause for this, a faulty toner sensor inside DV unit maybe? Any suggestions please?
    • 23009
    Are you using OEM toner & developer?
    • Polo-022
      • Sep 2007
      • 486
      Everytime!
      • mtech
        • Mar 2007
        • 307
        Check the mylar above the mag roller on the dv unit. Sometimes it is deformed (bent inward) or even missing!
        • mtech
          • Mar 2007
          • 307
          This mylar being deformed will also cause a build up on the main charge. Usually it is right in the middle. Also check the side seals. PSEL-0755FCZZ and PSEL-0754FCZZ. They also can cause toner/ developer leaking issues. Your problem is the seal over the mag roller. The part number can be found on the toner box section of the parts guide.
            • 23009
            I have to agree with mtech.
            I finally Googled the model #. This is a relative of the Panther. One of two things happen with those upper developer seals:
            1) The top cover over the mag roller warps downward scraping toner off of the mag roller. And yes, it sprays all over the primary, so it looks like a charge problem.
            2) The upper developer seal has a thick mylar backing. If the seal is peeled of but the mylar backing left behind, when the new seal is installed the seal gets closer and closer to the drum. I've seen developing units that had (4) backings plus a developer seal.
            If this is a cartridge machine, that doesn't change anything. The cartridge still has a developing section.
            • Polo-022
              • Sep 2007
              • 486
              Thanks a lot for your replies, very helpfull indeed! M/c was exposed to sun heat all day and mylar was curled inwards, maybe from high temperature inside. I reformed it and problem has gone-untill replacement. Thanks again...
