Sharp Ar 161
  • maks
    • May 2008
    • 75
    Sharp Ar 161
    ive got a message E7- subcode 05 in our machine it says ccd black level problem.does any one can give me a suggestion?also the tone indicator light up.thanks for any response..
  • swagreis
    • Jun 2008
    • 92
    first check the flat cable between CCD and MAINBOARD
    if not try to change the CCD unit
    if not try to change MAINBOARD
    • mtech
      • Mar 2007
      • 307
      Turn the machine on with the platen cover open and see if the copy lamp comes on. If it does then try replacing the CCD unit. If not then it could be the lamp or lamp circuit.
        • 23006
        I agree with mtech. Black level reference involves the lamp circuit, CCD, and image processing (takes place on the MCU). Try those things. If you change the MCU, make sure that the jumpers are set correctly for the model machine you have. For an AR-161 jumpers #1, #4, & #7 must be clipped.
        Oh, and for your toner light check the coupler & toner motor. On the early machines the toner motor shaft was made of plastic and twisted off. If you can find the coupler & spring install them on the new toner motor. If the motor & coupler are intact, just replace the toner.
        • maks
          • May 2008
          • 75
          ar 161
          thanks for the replies,yes the toner motor coupler was broken before that E7 code came..i try to fix the plastic which was broken..then i fixed it back..and yes i noticed that the lamp did go on..after turning on the power..now i know where to work on to regarding that code..ill try to order those parts that are needed..again thanks alot!!!!
          • mtech
            • Mar 2007
            • 307
            FYI, some part numbers:
            RMOTD0016QSZZ Toner motor
            NCPL-0002QSZZ Coupling gear
            MSPRC0024QSZZ Spring
            CLNS-0003QS51 Sould be the part number for the CCD/Lens unit.
            Be careful replacing the unit. There are three screws to level the unit and their adjustment is critical! Start by replacing the unit and not moving these screws, you may get lucky. If not, you will need a ruler and a lot of patience to get this adjustment right.
            Good luck
            • navaneetan
              just open the mirror,clean the white part on the glass,if it comes again,stick a white paper on the white part
              • mtech
                • Mar 2007
                • 307
                The paper trick only works on E7-11 when using the doc feed. You can also paint white out on the underside of the slit glass. This will not get rid of an E7-05 code though. It only works when the small reference plate is dirty, discolored or missing.
