MX-4101N firmware MODEL NOT MATCH
  • nathansipe
    just another tech
    • Aug 2009
    • 122
    [Misc] MX-4101N firmware MODEL NOT MATCH
    Best rule for troubleshooting.
    K I S S Keep It Simple Stupid
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: MX-4101N firmware MODEL NOT MATCH
    The latest firmware on Tradenet for the machine (with DSK) is v05.00.J2 (ICU)
    The DSK (commercial) firmware on its own is v04.02.Jc_A (ICU)
    • DavePo
      • Jul 2008
      • 305
      [ In 22-10 it is in fact an MX-4101N and the Security Kit says MXFR11. Am I missing something?
      Current Firmware is MAIN 01.00.JC BOOT 01.00JC LANG 01.15.P2 GRAPH 01.02.J2 IMG 01.02.J2 PCU 01.15.J2[/QUOTE]
      If 22-06 says DSK is MXFR11 and not FR11U then it has the Common Criteria firmware that is not upgradable.
      • nathansipe
        just another tech
        • Aug 2009
        • 122
        22-06 says MXFR11. Thanks DavePo.
          • 23008
          I'm forwarding the following suggestion form a long time friend of Copytechnet. He confirms DavePo's comments:
          There is a major difference between FR11 and FR11U in the data security kits. The FR11 is the common criteria version and is never updated from original, while the FR11U is the commercial version and is now up to version 05.01 for ICU main.
          Because the 22-10 data shows the common criteria model is installed, there is nothing more to be done. You can manually update the finisher firmware separately but the engine is up to date already.
          Either leave it alone or remove the DSK by hdd format and DSK flashrom removals back to originals.
          • tmaged
            Owner/Service Manager
            • Oct 2008
            • 1887
            Common Criteria DSK's are certified. If you upgrade a CC DSK, you've changed the properties of the DSK, making it no longer certified. Therefore, you cannot update a CC DSK machine. At least that's how I remember it.
            Hope that helps !
            -Tony
            www.dtios.com
            Become a fan on Facebook
