Sharp AR-m317 white lines in the middle of document
  • tibbs
    • Aug 2008
    • 225
    Hello, I just serviced a sharp AR-M317, changed the drum and blade, also the fuser. But now am getting a white line in the middle of the copy. I checked the the dev unit and the transfer roller but the same thing is happening.
    can anyone shed some light.
    thanks
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1887
    Re: Sharp AR-m317 white lines in the middle of document
    Check/replace the star wheels on the drum pickers.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • ZOOTECH
      Senior member of CRS
      • 3375
      Check for toner dust on the LSU slit glass.
      • Akitu
        Legendary Frost Spec Tech
        • Oct 2010
        • 2595
        Do a panic stop and determine if the toner is even making it onto the drum in the first place. Chances are there's some debris in your dev unit scraping it off the surface as it rotates.
        • ntbann
          • Jan 2012
          • 628
          Empty the dv unit, vacuum out, and put in new developer. Clean LSU slit glass.
            • 23009
            Though the other choices are a lot more common, I'll suggest that you check the charge grid for any lint. hair, or fiber. I'm talking about microscopic. Once you find it, a tooth brush is a handy tool to remove it.
            But to give good advice, I'll need to know more about this void line:
            1) Is the line in the feed or crossfeed direction?
            2) How wide is the line?
            3) Does the line have crisp distinct edges, or fuzzy indistinct edges?
            4) Does this line vary in width, length?
            I can give better advice with these answers. =^..^=
            • mabro1974
              • Feb 2013
              • 39
              Id go with charge not beensat correctly, check tht
              • Michmich123
                • Nov 2013
                • 24
                Please Show a Sample
                thx
                • Toner Boy
                  • Aug 2007
                  • 366
                  this would be too easy, but seal above developer roller dipping into the brush? They should be changed nearly every DV change or once a year.
